wes0778 Posted September 8, 2009 Share #1 Posted September 8, 2009 If I'm losing clutch fluid and there are no external leaks evident:think:, am I to assume that the fluid is goin into the crankcase? The clutch works fine and does not bleed down even while holding it disengaged at long stoplights. I've had to refill the master cylinder once in the last three months and it needs some fluid now. It did not start "using" fluid before I changed it the last part of May. Link to comment Share on other sites More sharing options...
gunboat Posted September 8, 2009 Share #2 Posted September 8, 2009 hi walter no way for the fluid to enter the crankcase. but i can't tell you were it's going if it's not showing up on the ground. don c. Link to comment Share on other sites More sharing options...
Marcarl Posted September 8, 2009 Share #3 Posted September 8, 2009 hi walter no way for the fluid to enter the crankcase. but i can't tell you were it's going if it's not showing up on the ground. don c. That being a very slow leak, it could be blowing it's way to the back of what's behind it on the bottom of your scoot. If you haven't serviced the slave cylinder yet, now may be a good time and I think you'll discover that it will be quite damp down there. Link to comment Share on other sites More sharing options...
BradT Posted September 9, 2009 Share #4 Posted September 9, 2009 Have Fun getting it out of there. A long T-handle allen wrench will come in handy. Then try and get it out. Brad Link to comment Share on other sites More sharing options...
