wes0778 Posted May 27, 2009 Share #1 Posted May 27, 2009 I have noticed that the clutch is starting to engage with the lever just barely off the grip. Also the bike tries to move forward if I start the engine in gear, with the clutch lever pulled all the way back, but does not move after the engine starts. It shifts fine and does not try to creep while I'm stopped at a traffic light, nor does it leak down while I'm waiting for the light to change. It just appears that an adjustment is needed. I have downloaded the repair manual for my bike (1998 RSTC) and cannot find any mention of adjustment. Suggestions anyone? Link to comment Share on other sites More sharing options...
RedRider Posted May 27, 2009 Share #2 Posted May 27, 2009 Based on the RSV design, there is no clutch adjustment to speak of. It sounds like you may need to change the clutch fluid and bleed the system. I suggest getting a SpeedBleeder for the clutch and it will make changing the fluid much easier. RR Link to comment Share on other sites More sharing options...
clmillsaps Posted May 27, 2009 Share #3 Posted May 27, 2009 (edited) It time for clutches.They be stuck together!And you may need to put in new clutch fluid.Yamaha says 2 years!! Edited May 27, 2009 by clmillsaps Link to comment Share on other sites More sharing options...
gunboat Posted May 27, 2009 Share #4 Posted May 27, 2009 i agree with rr. bleed the clutch system ( install a speed bleeder on the clutch slave cylinder ). i would go ahead and buy the speed bleeders for the front & rear brakes as well. best reguards don c. Link to comment Share on other sites More sharing options...
RandyR Posted May 27, 2009 Share #5 Posted May 27, 2009 I looked up speed bleeder. Here's their web page: http://www.speedbleeder.com/Motorcycle%20Sizes.htm#Yamaha btw, I don't see the older Tour Classics listed. Are their brakes & lines the same? looks like a future MD project for me. Link to comment Share on other sites More sharing options...
GeorgeS Posted May 28, 2009 Share #6 Posted May 28, 2009 First thing first, Bleed thru All of the old fluid. Replace it all. When you have cover off Resovoiur, there are two very small holes, in bottom, make sure they are BOTH, open. One is easy to see, the other is so small its hard to see. After bleeding, it should work OK. If not, you will have to rebuild the Master Cylinder, and Replace, or rebuild the Slave cylinder. Link to comment Share on other sites More sharing options...
Racer-X Posted May 28, 2009 Share #7 Posted May 28, 2009 Hello from Oh. When I changed my fluid I flushed system with Denatured Alcohol Before using DOT 5. Won't eat the rubber or seals. You can get at any ACE hardware cheep May save rebiuld! Link to comment Share on other sites More sharing options...
Shipper Posted May 30, 2009 Share #8 Posted May 30, 2009 My new 2008 RSTD does exactly the same thing. I found out that the clutch has no adjustment; and, because it's hydraulic, needs some warm up for the fluid to flow sufficiently for the clutch to open. Only answer I've found is to always park in "neutral" (to avoid the "forward creep), and to get used to the clutch play. No service needed on my unit. Good luck! Link to comment Share on other sites More sharing options...
Squeeze Posted May 30, 2009 Share #9 Posted May 30, 2009 The easy Thing you need to do to avoid creeping forward is to pull the Clutch Lever and held it for 2 or 3 Seconds before you start the Motor, and/or don't start the Bike in Gear. It's the Cohesion Force between Clutch Plates and Motor Oil. Link to comment Share on other sites More sharing options...
