Frozen Nuts!!
Yammer Dan
This sounds kind of nuts but I've been doing it for years. Works really well for smaller stuff anyway.
Take a can of compressed air, like Dust Off for cleaning computer, and hold it upside down and spray the nut until it's completly frosted over. Maybe repeat a couple of times until it's really cold to the touch. Then apply a little heat from a propane torch or a heat gun. I use a small butane torch to have better control of the heated area.
The rapid change from cold to hot really breaks it loose quick. I saw somewhere a whle back they were marketing a new product that you use for freezing nuts. About the same thing I imagine but you get to hold the can upright at about twice the cost of a can of compressed air.
Depending on size of bolts & nuts, Start with penetrating oil , let sit awhile
If they are small, take a hammer & punch & hit bolt in middle a few times
If its a nut use hammer & pin Punch & tap around the nut
Same goes for bigger ones , hammer the bolt , if you cant reach it, use a bigger punch
with the hammer.
I think this is the only time where size does matter
Gambler:banana:
