phochief Posted October 20, 2008 Share #1 Posted October 20, 2008 First, let me introduce myself....I just purchased a 2009 RSV and have only had it a week. Enjoying it so far.... I've ordered a number of add-ons so I'll probably be looking here for help. I searched and couldn't find an exact explanation of how to remove the front fairing (without damaging anything!). I would assume I need to remove the bolt under the headlight, and the three hex bolts on each side, but I don't know what to do next? I just don't want to break plastic tabs or crack anything. How do I remove the chrome around the headlight and the chrome piece below the windshield? Any specific instructions would be so helpful. Thank you and look forward to meeting some of you! David Link to comment Share on other sites More sharing options...
OutKast Posted October 20, 2008 Share #2 Posted October 20, 2008 The BIG thing is the chrome at the windshield. two screws hold it in from the back (inner fairing) side. after removing the two screws, lift the chrome UP along the windshield. DO NOT PULL OUT FROM THE WINDSHIELD. I do not know how the cross reference to other threads, but go to forum, then under second gen tech for "splitting the fairing" by Freebird. Link to comment Share on other sites More sharing options...
kbran Posted October 20, 2008 Share #3 Posted October 20, 2008 Here is a link if you didn't find it. http://www.venturerider.org/forum/showthread.php?t=494 Link to comment Share on other sites More sharing options...
bryan52577 Posted October 20, 2008 Share #4 Posted October 20, 2008 Not sure who the author is? I used it to do mine and it worked great! Had it off and put on visor on head light and replaced fairing in 36 minutes, with out a sweat! And still had time to look around in there to see what was going on . Fairing Removal Instructions http://www.venturers.org/NextGenTech/2ndGen/images/fairing1.gif Place the motorcycle securely on the side stand. Protect the front fender with a blanket or other covering. Remove the chrome front cowling cover by first removing its two mounting screws. Lift up each end of the cover, then push the center of the cover in and carefully lift the entire cover upward. The cover has tabs that insert into slots in the fairing. Do not use excessive force or the tabs can be broken. See Figure 1. Remove the six screws now exposed along the bottom of the windshield. Lift the windshield upward and remove it. See Figure 2. Remove the screw at the bottom of the chrome headlight ring and also the six screws which hold on the front of the fairing. Lift the front of the fairing off. If you already have the passing lamp kit installed, you will have to loosen the two screws holding the mounting bar to the lower triple clamp or there won't be enough clearance. This is where a 6 mm ball end allen screw driver comes in real handy. http://www.venturers.org/NextGenTech/2ndGen/images/fairing2.gif Following are the steps I took when I split my fairing along with some pictures that may help. You will need the following tools: http://www.venturers.org/Tech_Library/attachments/faring1.jpg Remove the plastic cover from the light bar. It simply snaps on and off: http://www.venturers.org/Tech_Library/attachments/faring2.jpg Next, if you have installed the Yamaha Passing Light Kit, then you will also have to loosen the two 6mm bolts that hold the light bar on. You DO NOT need to remove these bolts. Simply loosen them as much as possible without removing them. I usually loosen each side a bit at a time. http://www.venturers.org/Tech_Library/attachments/faring3.jpg Using a 3mm ballend or allen wrench, remove the four screws from the back side of the fairing on each side as shown below: http://www.venturers.org/Tech_Library/attachments/faring4.jpg Now, carefully remove the chrome windshield trim. Lift from each end simultaneously and carefully work towards the center kind of lifting up and back towards the windshield. When putting the chrome trim back on, start in the middle and then work to the outsides evenly. http://www.venturers.org/Tech_Library/attachments/faring10.jpg Below are some pictures showing the fragile tabs and where they align. It may help to see what these look like to better understand how to remove the trim. http://www.venturers.org/Tech_Library/attachments/faring11.jpg http://www.venturers.org/Tech_Library/attachments/faring12.jpg Now, remove the six windshield screws using a 3mm ballend or allen wrench. These screws also hold on the windshield so be careful. A second person to hold the windshield until all screws are out may be wise. After all six screws have been removed, carefully remove the windshield by gently lifting it straight up. On Yamaha windshields, most of the mounting holes are slots. The third hole from right (see photo) is an actual hole. By removing the third hole from right last it will help prevent the windshield from sliding out while you are working. This is true for the Yamaha windshields. It is uncertain which if any of the aftermarket windshields are the same. http://www.venturers.org/Tech_Library/attachments/faring6.jpg http://www.venturers.org/Tech_Library/attachments/faring9.jpg Remove the screw at the bottom of the headlight trim using a 4mm ballend or allen wrench. This is the last screw holding your fairing front on so be ready to support the fairing until you are ready to lift it out. http://www.venturers.org/Tech_Library/attachments/faring7.jpg You are now ready to remove the fairing front. Some members have said they can not remove the fairing front without removing the lightbar. I find it comes off quite easily if done right. You must pull out gently, then rotate the fairing front right as you continue to pull it out. I have the Yamaha Light Kit with standard bolts as well as the headlight visor and can get this off with no trouble. Here is a digital video clip of me removing my fairing front: http://www.venturers.org/Tech_Library/attachments/faring.avi about 2.5mb On my bike shown in this demonstration, I have removed the fork wind deflectors and do not use them. You may find it necessary to remove these in order to get enough tilt on the lightbar. Another option of course is to remove the lightbar bolts and gently set the lightbar on top of your blanket covered fender. If you do this, it would be advisable to secure the lightbar with some string to prevent it from sliding off the fender. Be careful not to pinch or stretch the lightbar wiring harness if you use this method. Finally, you can now get to work on whatever it is you needed to split the fairing for. Below is a picture of the fairing insides. http://www.venturers.org/Tech_Library/attachments/faring8.jpg To re-install, simply follow these procedures in reverse. No torque specifications are listed in my shop manual for any of these screws or bolts. Most of these screws are M5 which uses a general torque specification of 35 in. lbs. The screw in the headlight trim is a M6 screw and the general torque specification for that size is 80 in. lbs. Link to comment Share on other sites More sharing options...
phochief Posted October 20, 2008 Author Share #5 Posted October 20, 2008 WOW! You guys are great! Can't believe I got the answers I needed so quickly. Thank you, thank you! David Link to comment Share on other sites More sharing options...
KiteSquid Posted October 20, 2008 Share #6 Posted October 20, 2008 also, if you look in the VR Tech Section you can download a PDF copy of the factory service manual!!!!!!!!!! Also get the parts manual, to show you how it is assembled, and for part numbers if you need something... Link to comment Share on other sites More sharing options...
spotsy Posted October 21, 2008 Share #7 Posted October 21, 2008 If you install the Yamaha spot lights you can make a bracket or someone was selling them around here somewhere. Maybne someone can point you in the right direction. It will allow you to split the fairing in the future without having to remove the spot lights. Well worth the effort. Spotsy Link to comment Share on other sites More sharing options...
hipshot Posted October 21, 2008 Share #8 Posted October 21, 2008 If you install the Yamaha spot lights you can make a bracket or someone was selling them around here somewhere. Maybne someone can point you in the right direction. It will allow you to split the fairing in the future without having to remove the spot lights. Well worth the effort. Spotsy the brackets , i believe, are fabricated by old what's his name! oh, yeah SQUIDLEY! lol just jt:rasberry: Link to comment Share on other sites More sharing options...
BradT Posted October 21, 2008 Share #9 Posted October 21, 2008 Welcome to the site and congratulations on the new bike. Wow what directions those were great, Brad Link to comment Share on other sites More sharing options...
