User Tag List
Thanks Thanks:  0
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 16 to 22 of 22
Thread: Aim your lights
  1. #16
    Join Date
    Jun 2009
    Cambridge. Ontario
    Canada
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Really simple way to aim your light. Go out at night. Find a nice straight country road with very little traffic. Switch to high beam and adjust the light til' you can see as far a possible (while sitting with most of your weight on the bike. Do it 2up if you usually ride with a passenger). When you switch back to low beam you should then be able to see only a couple of hundred feet ahead. Works for me. I have HID installed and have yet to get flashed.
  2. #17
    Join Date
    Mar 2008
    London E3 3RG
    United Kingdom
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Can't you see the effect of your headlights on cars ???
    If you're following a car at a reasonable distance, then every now and then you should see the reflective number plate light up as you hit bumps (do you have reflective number plates over there ?) When you're closer, you should see the cut-off line of the dip beam across the boot of the car. If the interior of the car is all lit up, or you can see the wing mirrors getting lit, then your headlight is too high.
    As was said above, an easy check is to face a wall 30-40 m away in the dark and ensure that the light reaches the bottom of the wall, but does not come very far up it - certainly lower than the headlamp. That way you know it is pointing down.
    If you're concerned, use the measurements above, but you should be able to check for yourself if you're loaded more than usual by the effect of the light on the road and vehicles ahead.
    Just because you can doesn't mean you should.
  3. #18
    Join Date
    Aug 2009
    rahway
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    The tour classic I have is adjusted by 2 screws left and right just below center line. They dont control movement around horizontal or lateral axis . You have to turn both. It is hinged at top and in unison turning them in lowers the light. If there is too much turned in on one side it is still lower but right pushes light right and vise versa.
    I had to re adjust mine tonight after some one kept stabbing the brakes. They were really off. Now they are about 2 feet high at 30 feet.
    looks good to me.
  4. #19
    Join Date
    May 2009
    Cheney
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I have adjusted mine using a car in front of me. The majority of the light should hit the trunk area ( or just below the bottom of the rear window) and slightly above the license plate. This works great on most mid to standard size vehicles. This way I know my light is shooting right through the rear window into the mirror but give nice distance. I do it this way because I am lazy and rarely have a helper. The measurements given above I have used on cages and works fine.
  5. #20
    Join Date
    Dec 2010
    Huron (AKA Little Me
    CA
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    What we do is I put myself roughly 2-3 CAR LENGTHS away from a wall, and my dad puts up a white sheet (BE LEVEL!). I turn on the high beam and orient the beam. With a YVRMK2 you can see the center line, use that as your guide. Done right, when you go low beam it'll be just right. (Best to do it while your sitting on the bike and the bike is also leveled up)
    Not sure if it works with all H4s, I've got a H4 Phillips that I am SO throwing away, and getting something better (and aux lights... I want to ride at night.... want... want... want.... but can't..)
    Around here, its not other motorcyclists you have to worry about blinding you.
    Its the drivers. No one seems to know how to align their lights properly for any vehicle they drive, except for semi trucks... for some odd reason those are 9/10 correct....... better than cars 4/10 or trucks 6/20.
  6. #21
    Join Date
    Apr 2013
    Millbrook
    AL
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    How do you adjust your riding lights?
  7. #22
    Join Date
    Jun 2009
    Kitchener, Ontario
    Canada
    ON
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by chag67 View Post
    Take the bulb out of the pot and loosen the nut inside... just SLIGHTLY...enough that you can move it and it stays in place.
    Move the pot, put the bulb in and turn on the lights. Adjust them so that they are on the same level as your low beam. Start with the lights aimed parallel to the low beam so spacing on the wall shows about the same distance as the spacing on the bike. I have my left light aimed slightly in towards centre so it doesn't shine in the eyes of oncoming cars. The right bulb is slightly right to cover a bit of the shoulder of the road.
    When you get them aimed this way, take the bulbs out and tighten the nut down again, without moving the pots. Put the bulbs back in, test again (with you sitting on the bike and putting a good amount of weight on it) and when satisfied, tighen the bulbs in place.
    Keep in mind that when riding with a passenger the back end of the bike will sit lower, making the lights project higher than with just you on the bike. You may have to account for this and have the passing/driving lights aimed a little lower. Headlight is manually adjusted on the back of the fairing so you can easily adjust it on the fly depending on the weight of your passenger.
    Don
Similar Threads
  1. let there be lights!
    By az1103 in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 09-08-2008, 05:06 PM
  2. Hazard lights.
    By jprider4life in forum Watering Hole
    Last Post: 07-20-2008, 08:14 AM
  3. HID Lights
    By CrazyHorse in forum Watering Hole
    Last Post: 03-18-2008, 07:34 PM
  4. LED lights
    By rod in forum General Tech Talk
    Last Post: 02-16-2008, 03:37 PM
Tags for this Thread
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
