treeman Posted July 28, 2008 Share #1 Posted July 28, 2008 got a wobble at low speed with no hands on, speed up 40 no wobble Help. Link to comment Share on other sites More sharing options...
cmiles3 Posted July 28, 2008 Share #2 Posted July 28, 2008 Have you checked the tires and bearing? Pressure, tread separation, loose axle... Check the threads shown at the bottom of this screen. Link to comment Share on other sites More sharing options...
GeorgeS Posted July 28, 2008 Share #3 Posted July 28, 2008 Re do the torque on the upper triple tree clamp bolts. where the upper tubes are held in place. Re do the front axel, make sure all bolds for the front end are torqued properly. You might have to add some torque to the Steering head main Nut. 2nd gens are known for the Nut comeing a little loose. You might have to add, maby 5 to 10 degrees of rotation to the main steering head Nut. However tire Pressure is the first thing to check. ( both tires ) Have you been keeping the rear shock Air pressure to the correct setting. ?? I would also consider Draining and refilling the Fork Tubes with the Correct amount of fork oil, --- Just to be sure its correct . Link to comment Share on other sites More sharing options...
