I was working on a system to add a train horn to my first gen. It would mount into a 1 - 1/4 receiver hitch. I do not know if anyone makes a receiver hitch for the SVTC. This plug in also doubles as a cooler rack for day trips. Since the stinger part bolts on it would be easy to adapt the design to match any receiver hitch
Zoey I not awake yet but where is your horn mounted? Your probable gonna need to find a way to place two horns but I installed the snail horn by wolo on my sons bike. I think it would be fun trying to find a spot on your bike. You could "AS MUCH AS I HATE TO SAY IT" will probably need to ask over on the Yamaha facebook to see if one of them guys have done it yet. I have seen a lot of neat things over there. Most post right now are over empty usb, usb taken to long to install update. Mainly infotainment stuff. But I have seen lights, and couple mentions of the horn.
Never ride faster then your angel can fly. I am as free as the wind on my face.
Zoey,
Kuryakin makes some nice mounts and adapters in chrome or black to mount things just about anywhere.
My first guess would be to find a place near the engine guard...or on the guard and mount there. Run a relay off the battery to the horn...trigger the relay from the original horn circuit. Leave the original horn on the scoot and operational. Gives you a louder horn plus stock. Most of us have gone with the Stebel type or The Hellas. The Stebels (I have 2) have both worked great and so far for about 4 years on one and 2 years on the other. The Bolo's and others are copycats of the Stebels (or vice versa) and work just as well.
Hope this helps.
Victory Vision horn in place on the '18 SVTC.
I did trim the square corner of the horn, so no clearance issues at all.
http://www.venturerider.org/forum/attachment.php?attachmentid=113459
Before
http://www.venturerider.org/forum/attachment.php?attachmentid=113457
After
http://www.venturerider.org/forum/attachment.php?attachmentid=113458
NOHAWG, What did you need to take apart to get to the factory horn and wiring?
Sent from my iPhone using Tapatalk
That looks exactly like the Vision horn only with the correct spade connectors, so it actually would be direct plug-and-play. I'm betting mechanically and sound-wise, it's the same horn. BTW, mine won't sound unless the bike is running, unlike the stock horn for some reason.
