User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 8 of 8
Thread: 919 Honda Hornet Chain and Sprocket Change
  1. #1
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default 919 Honda Hornet Chain and Sprocket Change
    Well, I got my new chain and sprockets for my CB 919. Ive never changed a chain before, though I'm sure its fairly straight forward. I'm only really confused on the link that you put together. I was a little disappointed in the fact that the chain just came covered in sawdust... Is this to pull the moisture off of the chain? Ive read that you need a special tool, but mine looks like it just slips on?
    Click image for larger version.
    If you dont like the way im livin', you best leave this long haired country boy alone...
  2. #2
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Default Re: 919 Honda Hornet Chain and Sprocket Change
    I watched a video that said I should not use the clip style master link. They said they've had cases where they've come apart and damaged the motor or locked up the rear wheel. I don't have the riveting tool or the rivet style master link, so I guess it'll be awhile til it gets its new link
    Heres a video of the clip style link going together. Doesn't look too safe
    https://www.bing.com/videos/search?q...4&&FORM=VRDGAR
  3. #3
    Join Date
    Mar 2017
    Papillion
    NE
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    That video made that look very simple but they never show you that that's a 350-pound man using all his way to get that sucker on
    Sent from my SM-G935V using Tapatalk
  4. #4
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by s.tyler58 View Post
    It looks like it'll hold pretty well. I see my local Bomgaars sells master links. Don't know if it will make a difference since mine is an X-Ring chain or not
  5. #5
    Join Date
    Mar 2008
    Livonia, MI
    MI
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    There is no reason not to use a clip link. If you install it properly it'll be just fine. One thing the video doesn't mention - the closed end of the clip needs to point in the direction the chain rotates. That helps insure the clip doesn't pop off if something bumps it (piece of clothing, road debris etc.).
    I'm more concerned about the quality of the chain you got. X-ring chains normally come pre-lubed. In fact, I'm not sure it's possible to adequately lubricate any o-ring chain after the links are riveted. The whole point of the o-ring is to keep the lubricant in and dirt out, it'll be quite content to keep any lubricant applied after the fact out.
    You shouldn't need any special tool to do a clip link chain. It makes it easier to both cut the chain and press the side on the master link but there are other ways to skin those cats.
    1989 Venture Royale
    1982 XJ650 (Sold)
    www.thundervalleypower.com
  6. #6
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by MiCarl View Post
    It was 100 bucks with sprockets
    Here's a pic, it sure came slimey so I'm thinking its pre-lubed?
ID:	112569Click image for larger version.
  7. #7
    Join Date
    Mar 2008
    Livonia, MI
    MI
    Post Thanks / Like
    Mentioned
    6 Post(s)
    Tagged
    0 Thread(s)
    My comment was based on this:
    1989 Venture Royale
    1982 XJ650 (Sold)
  8. #8
    Join Date
    Nov 2009
    Norfolk
    NE
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Yeah I still really don't get what the dust is all about
Similar Threads
  1. Replies: 0
    Last Post: 01-21-2018, 04:40 PM
  2. Replies: 0
    Last Post: 08-20-2017, 09:20 PM
  3. xp3 HORNET Electronic Deer Avoidance gizmo?
    By Peder_y2k in forum Watering Hole
    Last Post: 06-04-2013, 09:36 PM
  4. .22 Hornet
    By Black Owl in forum Watering Hole
    Last Post: 11-14-2012, 08:25 PM
  5. hornet
    By rvcato in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 04-20-2009, 08:38 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
