User Tag List
Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 60
Thread: What brand of Premium, are you planning to feed this bad boy?
  1. #31
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: What brand of Premium, are you planning to feed this bad boy?
    Quote Originally Posted by Condor View Post
    So it's Sunday morning and I'm sitting here thinking... dangerous but entertaining... :-) There's 15% ethanol in every gallon of gas sold. With the amount of gas we burn in the US per day that's one hell of a lot ethanol. Since I've heard that ethanol comes from corn, is there enough corn grown every year to supply the ethanol needed to lace all the fuel with that evil stuff, and still have enough for the BBQ and popcorn????
    I just crunched some numbers and the ethanol needed for just one day is 2.3 million gallons of ethanol... Whew!!!
    https://www.eia.gov/tools/faqs/faq.php?id=23&t=10
    So I found that;
    Ethanol can be produced from a variety of feedstocks such as sugar cane, bagasse,miscanthus, sugar beet, sorghum, grain, switchgrass, barley, hemp, kenaf, potatoes,sweet potatoes, cassava, sunflower, fruit, molasses, corn, stover, grain, wheat, straw,cotton, other biomass, as well as many types of cellulose waste.....
    Sounds like we're going to have a food shortage.....
    ...or it can be produced from my wife's attempt at rice pudding. "Shhhhhhhhshhhhhh...glad she doesn't read the forums...for I'd be in deep ethanol right now...with some major back-firing's...."
  2. #32
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    66 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Flyinfool View Post
    Yes it is easy to extract the ethanol with water. BUT. What none of these people realize or mention is that by removing the ethanol you are also lowering the octane rating of the gas. Straight ethanol has approximately the equivalent of 100 octane. the oil companies use the ethanol as one of the ingredients to rise the octane to the desired level. So if you are going to a separation you would be best off starting with a higher octane gas. You do not want your octane to get to low and pop a hole in the top of a piston. I am to lazy to do the math right now to determine what starting octane you need.
    If that's the case how about adding a pint of 15% back into the ethanol free fuel...?? That would be one way to boost the octane... Another thought would be since they removed the lead way back when and replaced it with an ethanol or alcohol?? water mix, would it be OK to run the no ethanol fuel with the harder valves in todays engines?? Or would a lead additive be needed???
  3. #33
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Nope..or Shell (in Canada) would not have an ethanol-free premium on the market. In all the tests that you can view upon the internet...engines running this Premium...the valves look brand new, as well as the seats.
  4. #34
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    66 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by YamahaParExcellence View Post
    Interesting... What do they do to boost the octane?? Shell premium in California has 15% ethanol....
  5. #35
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    I'd guess that best to answer that, would be to go onto Shell Canada's site and see if the answer to your question is there. But in Canada...Shell Premium Nitro Plus at 91 octane rating IS totally ethanol free. Pure petrol...plus cleaner additives and friction modifiers. It's truly a really great blend, and I use it now in all my gas engine'ed lawn and garden equipment, my snowblower, the bikes...and the van. Nothing else, unless I am forced to use something in its place. Very great success with it. I am getting on average in my van...about a 15 percent better fuel economy, which pretty much cancels out any cost difference between the Premium and their Regular. Front end cost at the pump...but back end savings to negate it.
    Their Regular, though is like anybody's else's Regular. Ethanol laced...
  6. #36
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    66 Post(s)
    Tagged
    0 Thread(s)
    When touring on the bike I always had better performance with Shell, even here in the US. MOF it is the only fuel I use once out of California... We're more concerned with the stuff south of your boarder. What Shell Canada does with their premium to get away from ethanol can't be done down here. 15% ethanol is mandated in the US. But I think I found the answer. From the Shell/Canada web site....
    What makes Shell V-Power NiTRO+ Premium Gasoline different than other Shell grades?
    Shell V-Power NiTRO+ contains the highest concentration of the Shell Nitrogen Enriched Cleaning System and cleans up faster than Shell regular. In fact, Shell V-Power now contains seven times the amount of cleaning agents required by federal standards. The new Shell V-Power NiTRO+ formulation contains an innovative combination of two key cleaning agents that work together in harmony to provide the BEST TOTAL engine protection you can get. It provides unbeatable protection against gunk and corrosion, and superior protection against wear.
    The answer.... THEY US SEA-FOAM!!!
  7. #37
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    212 Post(s)
    Tagged
    0 Thread(s)
    Just curious, did you ever check to see if you ethanol free is actually ethanol free? Around here they are putting in way more ethanol that they are allowed to.
    Jeff Borowski . . 88 Venture standard
    There are 10 kinds of people that understand binary, those that do, and those that don't.
    Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  8. #38
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Yes...and if you also want to, you can call any of the customer numbers on the Shell Canada site...and verify that Canada wide, Shell Premium Nitro + (they use the plus sign as the blend on the gas pumps) is indeed totally ethanol free. That's the only one though...their regular and mid grade all have ethanol.
    Also, this is Shell's decision to give you unadulterated gas at the premium level. Some of the other major player's up here...also spike their premium blends with ethanol. So, that being I told my wife, that we will always fuel and 'butt' up...around finding a true corporate Shell gas station. I don't know about the convenience/shell also, combo's. I only speak for stand alone Shell gas stations. I think sometimes you can get the slippery sam happenings with convenience store/gas fills.
    If by your question did you mean did I ever use the water and separation thing on this thread? No...but my 15 percent better MPG, is there, because of no ethanol. Ethanol sucks for BTU energy output...and is the cause of so many people getting ripped off on MPG, forced to use the stuff. The first time I ever decided to use Shell Premium (Canada) Nitro (for its nitrogen content) plus (for the additive packages of cleaners and friction modifiers), I thought that something was wrong with my gas gauge. On the exact same routes to work, same traffic, same, same, the needle didn't start to move for over 2 days of the week. What a difference running this gas makes...and it is probably costing me nothing more by the next time I visit the pump. Front end sticker shock...negated by back end MPG obtainment. The fuel has more inherent BTU (British Thermal Units of energy measure) , so less is required from the injectors for any road condition, than when they were injecting gas/ethanol. I intend to use this for life, unless Shell Canada starts at any point to add ethanol. If they do...then I will go back to the regular with ethanol. To burn premium that has ethanol, (unless you need the higher octane rating) would have no 'juice' or benefit, IMO.
    BTW, if you know for a fact that they are adding more than legislated California Weights and Measures legislation allows for...I'd certainly lodge a complaint with the California agency responsbile for oversight, and see what shakes down. That is downright Consumer Fraud.
  9. #39
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    LOL...or something like it...and as I said at the first of this thread, since I am using this gas...I haven't bought anything else for additives (so there is another reason that the pump shock gets canceled out). I always used Sea Foam...and also used M.M.O. Now? Nope..so no added cost, other than this gas. You'd think I worked for Shell as a shill ...lol..but I don't. I just found a great gas blend that is making all my gas engines...garden, snow, toys, cars...run the best I have ever seen. On the grass trimmer...one pull. Chainsaw...one or two pulls. Before with ethanol? I carried my Rosary...in my back pocket...
    BTW, for whenever you and your better half, wish to visit the Great White North...well..not so 'white', in July, lol...come here on practically fumes...and then fill that bad boy of yours up with the Canadian 'Good Stuff'....lol. Take back a few gas cans with you...to California, along with three or four two-fours of beer. (You might need to use a trailer!) Put it on Craig's List, the gas...not the beer, lol...and rake the money in! LOLOLOL Who knows...maybe there is good money in this idea...sort of run it like booze in Prohibition. (Knock at the door). Door view slides open; "Yeah?" "I want some of that Canadian Shell Nitro". "Yeah? You got money?" "Yep..right here..." "Ok...meet me around back and stay quiet...". "No problem, and oh...Queasy the Mole sent me". "Yeah..good ole' Queasy". Door view panel snaps shut......... Hmmmm......
    Cheers,
    Joe
  10. #40
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    212 Post(s)
    Tagged
    0 Thread(s)
    I'm just jealous that no one sells real gas within 100 miles of me.
    Real gas is available up where I deer hunt, So in November I get 10 gallons of real gas to fill all of my things that will hibernate over the winter. And what is left is a treat for my winter engines.
  11. #41
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Man, that's got to be such a pain, Jeff! I guess that I will consider myself lucky to only have to go a mile or more away from the homestead. What we take for granted...small and large!
    Good idea though about bringing that gas back...and perhaps a couple hundred pounds of prime venison!
    Speaking of venison..that reminds me to make some more home-made, hickory smoked jerky. Waiting for a sale on chuck...lol.
  12. #42
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    66 Post(s)
    Tagged
    0 Thread(s)
    That was another thought I had. Is it actually ethanol free?? I guess a simple way to tell is take a pint of their Premium and do a colored water ethanol removal test.
  13. #43
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Here's a Toronto Star feature article on this blend..
    https://www.thestar.com/autos/2015/0...hell-says.html
    Quote within the article:
    "...At 91 octane, the new Nitro+ has the same rating as the V-Power it replaces, but also includes a new additive package that the company says will reduce engine gunk, corrosion, and wear. It also contains no ethanol."
    And this right from Shell Canada's site that I just searched and found:
    11. Is Shell V-Power NiTRO+ premium gasoline safe for all vehicles?
    • Shell V-Power NiTRO+ is effective in all gasoline-powered engines found in conventional, modern and hybrid vehicles as well as motorcycles, snowmobiles, and leisure marine vehicles.
    • Shell V-Power NiTRO+ premium gasoline in Canada does not contain ethanol.<--------------------------------------------------------(my arrow)
    For my fellow Canadian riders...and especially SVTC /Eluder riders..here is the ENTIRE scoop from Shell Canada on this blend:
    https://www.shell.ca/en_ca/motorists...XIvZmFxLmh0bWw
    https://www.shell.ca/en_ca/motorists...gasolines.html
    Another personal observation...in that the SVTC and Eluder are air/oil cooled...and that the greatest hot spot in the entire engine is the valve seat and valve body...so having a super clean valve body, and valve seat, and,...not being insulated by carbon and other pollutants (phosphor) will allow the max heat transfer AND, will not have the metal content heat escalating, due to those very combustion deposits. So, in my view...another greater push to use this or some similar fuel blend, for our babies...
    Post Edit: From yet another sub-header:
    • Shell V-Power Nitro+ premium gasoline contains 0% Ethanol.<<<<---------------------------------------------------------'Nuff said', lol"
  14. #44
    Join Date
    Feb 2018
    Winnipeg
    Canada
    MB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    co op premium and Costco premium in Canada are teir one and eythnol free
  15. #45
    Join Date
    Mar 2018
    Toronto
    Canada
    ON
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by ZOEYDOG View Post
    Can you point to internet confirms? Thanks...that would be my back up then.
    I found this...will look to see: Apparently, in Ontario, we have many choices...cool!
    https://www.pure-gas.org/index.jsp?stateprov=ON
    POST EDIT!!!!!
    OK..so this list isn't worth the paper it's printed on...check this out as reader comments:
    Esso - ESSO
    6192 Lundys Ln, Niagara Falls ON
    905-353-0020
    Ethanol-free octane ratings: 91
    GPS coordinates: N 43.08907 W 79.09732 (located from address)Updated by Demo, January 28, 2018 15:48 CST
    All their gas contains ethanol...they said their 91 was ethanol free...no sticker on pump...did sample test on their 91 it contained ethanol...told them to stop claiming the gas was ethanol free.
    Updated by sam, May 20, 2016 8:33 CDT
    I was just told by the attendant that all their gas has ethanol
    Joe
Similar Threads
  1. Replies: 40
    Last Post: 06-17-2016, 11:08 PM
  2. RSS News Feed
    By Freebird in forum Watering Hole
    Last Post: 11-08-2014, 10:25 AM
  3. Reg vs Premium
    By Seaking in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 07-08-2013, 07:58 PM
  4. premium gas ,, dont use it
    By Big Lou in forum Watering Hole
    Last Post: 07-07-2013, 11:09 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
