User Tag List
Thanks Thanks:  0
Page 1 of 2 12 LastLast
Results 1 to 15 of 28
Thread: help!!!! I broke down, whats the problem? I got towed home
  1. #1
    Join Date
    May 2015
    denton
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default help!!!! I broke down, whats the problem? I got towed home
    99 venture.Beautiful bike,51,000 miles.I am the second owner.My owners manual and repair manual showing the lever of the fuel petcock to be the pointer, not the blunt end.3 oclock is off, 6 oclock is on,12 oclock is reserve.The bike should run on on or reserve unless its almost out of gas.yesterday it wouldnt start.The tank looked bone dry.We had an imitation gas scare here in texas so finding a station with gas was a little hard.When I did all I could get was premium gas.So I took my gascan for my lawnmower,filled it up with premium and went to the bike.I poured the whole can it, it filled up the tank.problem is the can says it only holds 2.8 gallons.So I wasnt out of gas.I tried every position.Finally when it appeared according to the manual I had it on reserve and held the bike upright,level, the bike started and ran fine.I figured it just needed to fill up the fuel pump. Then this morning i was headed off to a CMA get together in a town 25 miles away.I had turned the lever to 3 oclock, meaning off to me.I put it back at 6 and again at 12.The petcock was dripping gas a little.I had pulled the choke out, so I pushed it back in.Finally it started and ran fine.The gas gauge showed almost full.Maybe 9/10 full.About 20 miles towards the 25 I intended going the bike quit like I had turned off the switch.I pulled off, tried the petcock in different positions, the bike started again. I got lost,stopped for directions, the bike was once again hard to start.At that point I said i better just go home.I was going up a fairly steep hill and the bike quit again.2 guys helped me get it to level ground.While waiting on a wrecker the bike would start up and take a throttle twist just fine.But i was afraid to try it again.here are my thought
    1.bad gas.The gas was selling like crazy here because everyone was freaking out buying gas,filling cans,etc.Maybe the pumps had got down to trash in the bottom.
    2.I put the gas in a lawnmower can,maybe it had some junk in it.
    3.The bike wasnt really on empty or it would have held more than 2.8 gallons.
    4.the petcock might be bad.
    5.When the choke is pushed in as far as it goes it still sticks out a couple inches.That appears like how it is made.It will pull out about 2 more inches when choking it on cold starts.
    6.The tube from the tank to the petcock wasnt kinked or broken
    7.maybe its the fuel pump.They cost $16.00. I have no idea how likely that is.
    8.It doesnt show any kind of fuel filter on these bikes in my manual.
    My plan: dump all the gas out.Buy a new unused gascan,put gas in the bike.Take off the sidecovers,check the fuel pump.The manual shows turning the petcock from off, to reserve, to on.The fuel should run out in all positions except off.If it doesnt run ou when its on or reserve I suspect the fuel pump.Any and all input appreciated.
    Proud owner of a 99 venture.faster than all others. Best of the 4 ventures I have owned.
  2. #2
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    61 Post(s)
    Tagged
    0 Thread(s)
    Default Re: help!!!! I broke down, whats the problem? I got towed home
    Fuel pump would be my guess.....
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
    "Some mistakes are too much fun to only make once." - Well worn saying
    "Great ideas often receive violent opposition from mediocre minds." Albert Einstein
  3. #3
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    So a couple of things.
    Yes there is a fuel filter, actually there are two. Primary one is beside the battery behind the left side cover near the fuel pump area, it is a real pain in the butt to get to and get out, it is mounted with a rubber strap that is secured to a metal bracket. The secondary fuel filter is part of the petcock, if you pull the petcock out of the bottom of the tank you will find it has small cone shaped screens on the inlets. Any or all of them could be plugged.
    Yes fuel pumps on these bikes go bad and there has been a pretty sizable number of folks that have had issues with them.
    If this happens again, very carefully remove the gas cap and listen for a sucking or whooshing type noise, that would indicate that the tank vent is plugged, some have had issues with critters crawling up the vent tube and making a nest or getting stuck and die , this will restrict the air getting back into the tank to replace the gas volume removed as the bike is ridden, causes a vacuum and the bike dies of fuel starvation. Easiest way to check for this is to pull the vent line off the pipe on the tank and blow some compressed air through it, then check to see if anything came out.
    Hope this helps.
    Steve K
    Edgewater , FL
    And the LORD said "Thou shalt have dominion over all of the animals, Except of course the cat."
    DR. Goldwing; has the antidote for the blues
  4. Likes mm482 liked this post
  5. #4
    Join Date
    May 2015
    denton
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by M61A1MECH View Post
    Hope this helps.
    I dont think any bike for the last several decades was made without a mesh screen filter on the petcock as it goes up in the tank.I totally forgot about that.I will definitely do the listen thing with the gas cap.Where would you buy a fuel pump, or any parts that you might need? There are so many places. Which is best?
  6. #5
    Join Date
    Aug 2010
    Goose Creek
    SC
    Post Thanks / Like
    Mentioned
    10 Post(s)
    Tagged
    0 Thread(s)
    You said that a little gas came out of the petcock? I am assuming you had the fuel hose off the bottom and it was not a steady stream? If this is the case the problem is in the tank either the vent hose is clogged or the petcock screen is clogged like has already been said.
    With the hose off the petcock take the gas cap off, if gas starts to flow it is the vent hose, if not it is the petcock or screen.
    If I am reading your post wrong and you did have a good stream of gas out of the petcock the fuel filter is clogged or your fuel pump is bad. When you turn your ignition switch on you should hear the fuel pump click for a couple of seconds if no clicking the pump is most likely bad.
    The reason your bike started after sitting is because some fuel is getting by and filling the bowls but you are running it out before they can refill.
    You can also take the hose off at the carbs and see if you have good flow.
    Here is a post for an alternative fuel pump, an OEM is a couple hundred bucks last time I checked.
    http://www.venturerider.org/forum/sh...ump-Conversion
    Crazy Joe
    Retired Navy Chief
    99 RSV X 2;2006 Ultra Classic;2012 GL1800
  7. #6
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by cruiserlover View Post
    Joe has some very good advice, if you find the fuel pump is the issue here is a link to get the points for the fuel pump, they ae what normally go bad on the pump.
    http://www.powersportswarehouse.com/...Product/158278
    Steve K
    Edgewater , FL
  8. #7
    Join Date
    Aug 2006
    Greenville
    NC
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This link will show you the fuel filter and fuel pump.
    http://www.venturerider.org/forum/sh...he-fuel-filter
  9. #8
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    So when your done messing around with the old point type pump. Here is a post on how to install a solid state pump. No points to burn up.
    2013 Black Victory XCT
    Trailers are for when your bike is broke, aint they?
    https://www.epgsoft.com/VisitedState...TX.VA.WV.AR.AL
  10. #9
    Join Date
    May 2015
    denton
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    I had no idea it had points.I assumed it was just like any other pump with diaphragms,one way valves etc.Your link has same part number and 2 prices.Both are the same,will work on a 99 I assume.So the cover on my pump comes off, replace this part, good to go? Thanks.
  11. #10
    Join Date
    May 2015
    denton
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by mm482 View Post
    wow! man, doesnt get any clearer than that.Thanks so much.I had a ford van once, filter got clogged, not enough fuel line to run without it, took a hammer and nail, back on the road.not an option here.Thanks a bunch.
  12. Likes mm482 liked this post
  13. #11
    Join Date
    May 2015
    denton
    TX
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by djh3 View Post
    great how to tutorial.I dont really need to know but if it doesnt have points system how does it work.Like a purely electrical pump with some sort of switch that opens and closes with the ignition key?
  14. #12
    Join Date
    Jan 2016
    Stephenville
    TX
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Bill Donohue
    2001 RSV 41876 miles
  15. #13
    Join Date
    Sep 2010
    Sebring FL
    FL
    Post Thanks / Like
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    I have no idea what makes it work. Magic I guess. Solid state no contacts I presume its a timed circuit. Wire it rite in on the wires from the OEM pump. Prices are different depending on where you source it. I needed one "now" and my autozone had one. If I could have waited I would have looked around more. There is also a "facett" brand pump that has a check valve to prevent flow with out the pump on. It is pricier than the MR Gasket but thats why its FAA approved for aircraft.
  16. #14
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    3 Post(s)
    Tagged
    0 Thread(s)
    The pump works by energizing a coil that pulls a piston in once it hits bottom the coil de-energizes and a spring either pulls or pushes the piston back to the starting location and the coil is energized again, repeating the cycle. The power to the coil is turned off and on either by a set of points that open and close that make the circuit complete or by an SCR or SSR(Solid State Relay) which is is essentially just a heavy duty transistor, the transistor gate is opened or closed by application of voltage to the proper leg this allows it to act like a mechanical relay to allow voltage thru or open and stop voltage, same as the points but no moving parts to break down or wear out.
    Yes magic.
    More info you do not need , https://en.wikipedia.org/wiki/Solid-state_relay
    Steve K
    Edgewater , FL
  17. #15
    Join Date
    Jan 2013
    Caro, MI
    MI
    Post Thanks / Like
    Mentioned
    29 Post(s)
    Tagged
    0 Thread(s)
    Facet with a check valve bike has a lot more power and no HYDROLOCK
Similar Threads
  1. No spark problem stuck 30 mi from home
    By pmelah in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 06-08-2013, 12:28 PM
  2. Has anyone towed using one of these?
    By cabreco in forum General Tech Talk
    Last Post: 02-14-2012, 09:28 PM
  3. Help, broke down 2,000 miles from home
    By Seaking in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 08-15-2009, 10:16 PM
  4. Whats the problem?
    By FROG MAN in forum Watering Hole
    Last Post: 09-24-2008, 09:19 AM
  5. Venture gets towed
    By tx2sturgis in forum Watering Hole
    Last Post: 04-08-2008, 06:43 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
