k9cottage Posted September 13, 2017 Share #26 Posted September 13, 2017 i took one look at where the fuel filter was and decided to move it with a bit of extra fuel hose it fits nicely under the seat easy to see and replace Link to comment Share on other sites More sharing options...
cruiserlover Posted October 16, 2017 Author Share #27 Posted October 16, 2017 The pump works by energizing a coil that pulls a piston in once it hits bottom the coil de-energizes and a spring either pulls or pushes the piston back to the starting location and the coil is energized again, repeating the cycle. The power to the coil is turned off and on either by a set of points that open and close that make the circuit complete or by an SCR or SSR(Solid State Relay) which is is essentially just a heavy duty transistor, the transistor gate is opened or closed by application of voltage to the proper leg this allows it to act like a mechanical relay to allow voltage thru or open and stop voltage, same as the points but no moving parts to break down or wear out. Yes magic. More info you do not need , https://en.wikipedia.org/wiki/Solid-state_relay great info .thanks. Link to comment Share on other sites More sharing options...
cruiserlover Posted October 16, 2017 Author Share #28 Posted October 16, 2017 i took one look at where the fuel filter was and decided to move it with a bit of extra fuel hose it fits nicely under the seat easy to see and replace yest.they are in a terrible location Link to comment Share on other sites More sharing options...
