Raven1294 Posted August 29, 2017 Share #1 Posted August 29, 2017 Where do I find the plug that goes from the R/R to the stator on a 05 RSTD? Want to check it and add some dielectric grease to it if needed....Thanks Link to comment Share on other sites More sharing options...
etcswjoe Posted August 29, 2017 Share #2 Posted August 29, 2017 Where do I find the plug that goes from the R/R to the stator on a 05 RSTD? Want to check it and add some dielectric grease to it if needed....Thanks Two plugs: One right under the battery box, you should be able to get to it from the left side, it is white with three conductors, the second one is to the R/R itself right under the radiator. Link to comment Share on other sites More sharing options...
Raven1294 Posted August 29, 2017 Author Share #3 Posted August 29, 2017 Two plugs: One right under the battery box, you should be able to get to it from the left side, it is white with three conductors, the second one is to the R/R itself right under the radiator. Wow ok thought it was one plug with one side going to R/R and the other end of the plug going to Stator, at least thats the way it is on my Honda shadow ace tourer, so two separate plugs on the RSTD Link to comment Share on other sites More sharing options...
etcswjoe Posted August 29, 2017 Share #4 Posted August 29, 2017 The R/R on these bikes have a single plug that feed the battery and the stator, The stator wires are white with the other plug in between and the battery wires are black and red. Link to comment Share on other sites More sharing options...
MiCarl Posted August 29, 2017 Share #5 Posted August 29, 2017 On your Honda the stator and regulator/rectifier were near each other and plugged together under the seat. On your RSTD the stator plugs to the wire harness under the seat (below the battery) and the harness plugs into the regulator/rectifier which is under the radiator. Link to comment Share on other sites More sharing options...
Raven1294 Posted August 29, 2017 Author Share #6 Posted August 29, 2017 ok thanks everyone! Link to comment Share on other sites More sharing options...
mm482 Posted August 29, 2017 Share #7 Posted August 29, 2017 This is the stator end plug, that's under and in front of the battery and fuel filter. Link to comment Share on other sites More sharing options...
