User Tag List
Thanks Thanks:  0
Likes Likes:  0
Results 1 to 8 of 8
Thread: Iso diode assembly location on a 2006 Royal Sar Venture 1300
  1. #1
    Join Date
    Aug 2017
    Whitesboro, Texas
    Us
    Tx
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Iso diode assembly location on a 2006 Royal Sar Venture 1300
    I am trying to find the location of this diode assembly . I have been told this is the problem causing my bike to die when put in gear. I am putting a pic of the schematic that says it there with wire colors. Please help!
  2. #2
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    80 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Iso diode assembly location on a 2006 Royal Sar Venture 1300
    On page H10 of the RSV parts pdf, it shows the diode assembly comes off the main wiring harness near a fuse block. I'm not so sure I would trust that, but if you look under the tank, on each side of tank and below where the main fuse assembly is, it might be there. It simply going to look like a small sealed unit coming out of the harness. At the end of the short wires will be a little bulge...the diodes. At least that's what I picture in my brain.
    That said. Diode assemblies rarely go bad unless the electrical system was shorted. In this case.... This set of diodes makes sure power to the sidestand switch is going the right way and doesn't come back wards. I would test the sidestand switch first as that's a more common failure.
    The manuals and parts pdfs are downloadable from this site for free.
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
    "Some mistakes are too much fun to only make once." - Well worn saying
    "Great ideas often receive violent opposition from mediocre minds." Albert Einstein
  3. #3
    Join Date
    Aug 2017
    Whitesboro, Texas
    Us
    Tx
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I did short sustem like a dumb ass I didn't disconnect battery. I did a continuity test on stand switch and it checks out fine. Thank you sir I am going to try and locate it today. Where would I get this diode?
  4. #4
    Join Date
    Dec 2013
    Green Valley
    AZ
    Post Thanks / Like
    Mentioned
    80 Post(s)
    Tagged
    0 Thread(s)
    See if you can see the diode values on the old ones, then build the pack yourself. Nothing more than one or more diodes soldered together in one direction. Diodes are usually marked as to direction. Maybe someone here can figure out values....
    As to where to buy? Any electronics place should have them. Very common. Shame Radio Shack is gone.... They were my main source for little parts like diodes.
    USAF
    AFRTS Turkey
    1970-1973
    Patriot Guard
  5. #5
    Join Date
    Aug 2017
    Whitesboro, Texas
    Us
    Tx
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by videoarizona View Post
    Thank you sir
  6. #6
    Join Date
    Aug 2017
    Whitesboro, Texas
    Us
    Tx
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having a hard time finding it. There is a fuse block behind front right fairing and one behind cover by radiatir over flow tank. I cant tell which one to look at. Any advice would help. I cant even find anything that connects to blue and white wires.
  7. #7
    Join Date
    Oct 2006
    Edgewater, FL USA
    FL
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Tsarge View Post
    Try looking at this picture from Parts Fish, find item 19.
    http://www.partsfish.com/oemparts/a/...3/electrical-1
    Cheap enough to buy the assembly and then you have something to look at and compare as you hunt for it.
    Steve K
    Edgewater , FL
    And the LORD said "Thou shalt have dominion over all of the animals, Except of course the cat."
    DR. Goldwing; has the antidote for the blues
  8. #8
    Join Date
    Aug 2006
    Greenville
    NC
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The fuse box you are looking is located behind the left passenger floor board. The diode should be very close to it.
    Earl
Similar Threads
  1. Replies: 9
    Last Post: 09-27-2015, 02:49 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
