User Tag List
Likes Likes:  0
Results 1 to 9 of 9
Thread: Are there any symptoms before you lose 2nd gear?
  1. #1
    Join Date
    Oct 2014
    MKE
    WI
    Post Thanks / Like
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default Are there any symptoms before you lose 2nd gear?
    My headline sums it up....I have an '84 Venture Royale with about 24k, my case DOES have the marking, but from what I've read, that doesn't always mean 2nd gear was fixed ( sometimes it means the stator oiler was added).
    So, are there any symptoms before 2nd gear drops? Or does it just happen one day?
  2. #2
    Join Date
    Dec 2014
    Bear Island, NB
    Canada
    NB
    Post Thanks / Like
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Are there any symptoms before you lose 2nd gear?
    When 2nd gear went south on my '84 there were no early warning signs that I recall. It just started to "slip" under load - getting progressively worse. Mine happened around 80k kilometres (50k miles).
  3. Thanks Patmac6075 gave thanks for this post
  4. #3
    Join Date
    Aug 2006
    Ivydale
    WV
    Post Thanks / Like
    Mentioned
    34 Post(s)
    Tagged
    0 Thread(s)
    Crank it hard in 2nd and it will start to "Pop" at high RPM's. You will feel a slight jerk or hesitation. Best way I can describe it. Baby it in 2nd help?? I wouldn't know. I cain't ride that way....
    1st GENS RULE
    Faded Blue is the fastest.
    "Blue Beast" will live forever
  5. Thanks Patmac6075 gave thanks for this post
  6. #4
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    50 Post(s)
    Tagged
    0 Thread(s)
    Yup, that's pretty much how it goes! It starts to drop out under heavy acceleration and just keeps getting worse...
  7. Thanks Patmac6075 gave thanks for this post
  8. #5
    Join Date
    Aug 2013
    saint petersburg florida
    FL
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Prior to "slipping" wheel stands and burnouts? On my old one I broke the drive shaft first. Never lost second, I slowed down a bit after that.
  9. Thanks Patmac6075 gave thanks for this post
  10. #6
    Join Date
    Aug 2006
    Manchester
    TN
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    When mine first started, I noticed that when the bike was partially warmed up and at medium throttle, I could feel it go out and back into gear. This was at 77,000 miles. By the time it got to 82K, 2nd was pretty well unusable.
  11. Thanks Patmac6075 gave thanks for this post
  12. #7
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    If you really want to make your bike a better accelerating and a better cruising bike, get a complete trans from a 2nd gen bike and a early V-Max final drive, This gives you a 10% lower 1st gear, 5% lower 2nd, 3rd and 4th are the same and about a 5% higher 5th gear. This is a great combination for the early Venture, whether it is for a second gear fix, or just improving the later 1st gens. I did this on mine and love the combination.
    If you are somewhat mechanically inclined and have some good tools and a place to do it, this is not a really hard job. I still have a complete 2nd gen setup out in the garage.
    Randy
    Ride as though you are invisible, not invincible.
  13. #8
    Join Date
    May 2016
    Menasha
    WI
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Venturous Randy View Post
    Randy
    Will this combo work on the XVZ12 or only on the later 13 engines?
    Ride for the love of the road and the freedom it offers.
  14. #9
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    17 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Air Ready Auto View Post
    Yep, I did it on my 83 and wish I could have done it a long time ago.
    Randy
Similar Threads
  1. Won't crank...see symptoms below
    By jasonm. in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 10-27-2013, 09:00 PM
  2. If your carbs are out of sync, what symptoms?
    By jurob in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 10-25-2011, 07:57 PM
  3. Symptoms?
    By BigBear in forum Second Generation Venture Tech Talk ('99 - '13)
    Last Post: 01-01-2011, 10:43 AM
  4. BoomerCPO..you lose something?
    By Ruffy in forum Watering Hole
    Last Post: 07-02-2010, 08:42 PM
  5. symptoms of a stator going bad?
    By bobcat in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 08-24-2008, 11:42 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
