crue69 Posted June 22, 2017 Share #1 Posted June 22, 2017 Hi all. I believe I have a leak in the clutch lines down low. If I let the bike sit a couple of days, I will get a couple of drops which I believe is brake fluid. when I fire the bike up, I will get smoke on the left side as something is leaking on the exhaust. I think this is the clutch line leaking behind left middle gear case cover or even the clutch release assembly itself. I have had to periodically add fluid to clutch...My question is, is this a problem anyone has encountered and I'm guessing there is a gasket for that middle cover? Thank you in advance Link to comment Share on other sites More sharing options...
Patmac6075 Posted June 23, 2017 Share #2 Posted June 23, 2017 Crue, I rebuilt my clutch hydraulics a couple of years ago. I did a write up http://www.venturerider.org/forum/showthread.php?116337-Clutch-Hydraulic-Rebuild-Tutorial send me a pm if you have any questions. Link to comment Share on other sites More sharing options...
