ronjolly Posted March 21, 2017 Share #1 Posted March 21, 2017 Has anyone hard of a coil spring to assist the air shock one a RDST or Venture?? if so where and how much. I have 137K on my RSTD 08 getting a lil soft, If you know where to find on Please send note, Tks Ron Link to comment Share on other sites More sharing options...
vzuden Posted March 21, 2017 Share #2 Posted March 21, 2017 http://www.worksperformance.com/pdf/app_guide/street.pdf http://www.hagonshocksusa.com/HagApps8.htm These are the two manufacturers most of use beyond the factory original Link to comment Share on other sites More sharing options...
RSTDdog Posted June 4, 2017 Share #3 Posted June 4, 2017 http://www.worksperformance.com/pdf/app_guide/street.pdf http://www.hagonshocksusa.com/HagApps8.htm These are the two manufacturers most of use beyond the factory original No add on available for the factory shock. It is not serviceable or rebuild-able. Just the two replacement shock options already provided above. I opted for the Hagon with the Heavy duty spring option on my RSTD when I had it. Well made, good value IMO. No air adjustment on either of the above options, but with improved capacity of the spring which is also adjustable for preload you don't need it. Link to comment Share on other sites More sharing options...
