User Tag List
Likes Likes:  0
Results 1 to 12 of 12
Thread: Discovered Something Tonight About '83 Only Ventures!!
  1. #1
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    51 Post(s)
    Tagged
    0 Thread(s)
    Default Discovered Something Tonight About '83 Only Ventures!!
    While looking at the schematic for the fuel pump relay on the '83 model only, I discovered that the fuel pumps on that year only do NOT shut off after the initial few seconds before the bike starts!!! That safety feature was not incorporated until the '84 on up models!!! So, if you own an '83 your fuel pump should keep clicking and clicking until the fuel bowls are up to full pressure!!
    I'm sure there is a reason for that safety feature being added after '84, I always assumed it was to prevent the possibility of getting a hydro lock from too much fuel pressure, or in the case of a stuck needle valve staying open. Anyway, the gray line from the number 2 coil trigger from the TCI that also feeds the tach is what restores the fuel pump relay. On the '83 there is no gray wire to the relay, just a duplicate R/W line. That relay is a special relay that has a "Time constant" circuit in it that makes it run initially for a few seconds when the bike is first turned on...
    Just wanted to pass this on!
  2. Thanks BlueSky gave thanks for this post
  3. #2
    Join Date
    Aug 2006
    Ivydale
    WV
    Post Thanks / Like
    Mentioned
    39 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Discovered Something Tonight About '83 Only Ventures!!
    I somehow knew that. Have pumped fuel into a container from 83. Tried it on 85 and it shut down. But didn't think it out. Got what I wanted at the time done so.....
    1st GENS RULE
    Faded Blue is the fastest.
    "Blue Beast" will live forever
  4. #3
    Join Date
    Jul 2016
    Joplin
    MO
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    No wonder mike is a kick butt rocking machine it dont shut up lmao!!!
  5. #4
    Join Date
    Jul 2016
    Joplin
    MO
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    I will have to definately try this theory. I am thinking mine does shut off after a couple of clicks. Because when I had my carbs off I forgot about the gas still being on and it only pumped a few seconds but after I realized what I did I turned the key back off... So I will test this in the morning by hooking hose to outlet and stick it in gas can just to see...
  6. #5
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    51 Post(s)
    Tagged
    0 Thread(s)
    Just keep in mind as soon as the system reaches full pressure the pump can't pump anymore so it will stop clicking. 12 volts will still appear across the pump, though...
  7. #6
    Join Date
    Aug 2006
    Johnson City TN
    TN
    Post Thanks / Like
    Mentioned
    18 Post(s)
    Tagged
    0 Thread(s)
    My 83 will click for a few seconds when I turn the key on and I will then flip the kill switch off and on and it will again click for a few seconds. If I will keep repeating this, mine will start to click less and less until it stops. So, if what you say is correct and I understand it right, my 83 works like an 84 and up.
    Randy
    Ride as though you are invisible, not invincible.
  8. #7
    Join Date
    Jul 2016
    Joplin
    MO
    Post Thanks / Like
    Mentioned
    4 Post(s)
    Tagged
    0 Thread(s)
    Venturous only if we hook up a different fuel pump..... the one we have has the built in safety features, just the relay keeps running. I have a fuel pump somewhere I could try.. If I can remember what I did with it. But it was off of a chevy luv I had...
  9. #8
    Join Date
    Aug 2006
    Brantford
    Canada
    ON
    Post Thanks / Like
    Mentioned
    55 Post(s)
    Tagged
    0 Thread(s)
    I think basically the fuel pumps all run the same. It's a spring and solenoid setup. The solenoid draws the shaft one way, then shuts off by the limit switch, a spring draws it back to the starting point and the cycle starts again. The spring stroke provides the pumping and pressure. The relay is there just to limit the time of running when the bike is not running.
    It's nice to be the same
    But
    It's great to be different!
  10. #9
    Join Date
    Jun 2007
    Cudahy, WI
    WI
    Post Thanks / Like
    Mentioned
    201 Post(s)
    Tagged
    0 Thread(s)
    Or is it possible that the 2 second feature was added during the 83 model year.
    Jeff Borowski . . 88 Venture standard
    There are 10 kinds of people that understand binary, those that do, and those that don't. Sometimes the thoughts in my head get bored and go for a stroll out through my mouth (or fingers). This is never a good thing.
  11. #10
    Join Date
    Aug 2006
    Carmichael CA
    CA
    Post Thanks / Like
    Mentioned
    63 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Flyinfool View Post
    That's my thinking as well. I consider the '83 as a BETA model, with small tweeking changes made during production. Even the '84 occasionally. I.E. the choke set being '84 only...
  12. #11
    Join Date
    Oct 2008
    Moore, OK
    OK
    Post Thanks / Like
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Electric fuel pumps will automatically shut off when the preset back pressure is reached.
    I think the manufacturers want the fuel to shut off in case of an accident.
    the fuel pump is allowed to run for only a few seconds, when the key is first turned on, to pump fuel into the carbs.
    The electric pump can constantly run when the engine is running.
    My Ninja has the same thing. All cars with electric fuel pump will have the same feature.
    BTW: To test the electric fuel pump in a car or bike the fuel pump relay is bypassed.
    Both of my Ninjas are permanently bypassed because I couldn't figure out why they would not work.
    They have been bypassed for years
    1992 Yamaha Venture Royale
    1985 Yamaha Venture Royale with 1300 engine & Vmax cams
    1999 Kawasaki ZX11 Ninja
    1993 Kawasaki ZX11 "Adventure" custom
  13. #12
    Join Date
    Aug 2006
    Arcade, NY
    NY
    Post Thanks / Like
    Mentioned
    51 Post(s)
    Tagged
    0 Thread(s)
    That is quite possible, I am just going by the factory wiring diagrams for the '83 versus the '84. Go to the Technical Library and view the schematics at the fuel pump. On the '83 the R/W wire goes to two places on the relay whereas on the '84 the gray line from the TCI goes to the one connection...
Similar Threads
  1. Replies: 17
    Last Post: 09-14-2015, 02:34 PM
  2. New animal discovered
    By fishrepair in forum Jokes and Humor
    Last Post: 01-24-2015, 02:13 AM
  3. Winter Project discovered.
    By cabreco in forum First Generation Venture Tech Talk ('83 - '93)
    Last Post: 12-12-2012, 01:54 PM
  4. Tonight's the night
    By rosebud in forum Watering Hole
    Last Post: 11-25-2011, 11:21 PM
  5. Chat Tonight
    By mini-muffin in forum Watering Hole
    Last Post: 04-30-2008, 06:20 PM
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
